Electric cutout before H pipe and performance.
Eagleee
Hello there. I'm running stock headers with no catalytic converters with Borla Pro XS mufflers. I'm thinking to go with electric cutouts before the H pipe but will it hinder performance? Is it going to break/hurt anything? Sorry I'm just learning with the car stuff, so please excuse me. Thank you so much for your replies!
06 T-RED S/C GT
Carnegie, PA
From my understanding, electric cutouts do not hinder performance. IIRC they function similar to that of the active exhaust systems available from the factory for current S550 models :shrug:
Granatelli
YEP... There is no drawback to adding cut outs in fact besides making the car as louder as possible, it could result in an increase in horsepower because it will free up the exhaust back pressure if there is any. I would recommend you consider running an oval set up because it would give you perfect ground clearance. Lots of folks are confused by installing oval on to round tube but its easy.
Here is a video of how a typical install would go
06GT-
Dallas
How is ground clearance? Do you have photos of the cutouts?
AHaze
Edmonton, AB
OP specifically mentioned having the cutouts before (I assume meaning upstream) of the H-pipe. Are we all sure that has no detrimental effects? That would mean all the OEMs have been installing crossovers on their dual exhaust systems for no reason.
My understanding is that the crossover improves exhaust scavenging which increases power, generally in the mid range.
The newer Mustangs with the active exhaust have the valves integrated into the mufflers well behind the crossover so not really directly comparable.
