So, a while back my 3 valve started thinking to itself "Man, I wanna eat some spark plugs and ruin a phaser." So, it decided to do that. When I went to put the new phaser on, it didn't line up somehow and I decided to just take it apart and retime it. I figured better safe than sorry right?
Now, I've got everything buttoned up back together.
I went to hook the battery up and it was dead. Ok, no problem. Hooked up my trickle charger and let it sit overnight. This morning, charger says it's full/maintaining, sweet. Put the key in the ignition, press in the clutch, and again I get nothing. The battery gives power when the key is in the on position, radio plays fine, dash lights up perfectly. However, the moment I move the key to crank it, it just acts like it dies. Ok, maybe the battery is just toasted and ruined. I hooked it up to my honda just to see if it would (CCA was way lower on the honda) and just like that it cranked right up. So it's not the battery.
What I found interesting was, if I attempt to start it, it dies and such (loses power to the dash, everything freaks out, etc. If I disconnect the battery for a split second and then reconnect it, it acts like nothing ever happened. Until I try to start it again, then it simply freaks out as it has prior.
I checked the grounds on the front RH side, the one on the RH side of the engine, the RH strut tower side, and the ones in the trunk. All seemed perfectly fine. I didn't bother checking the ones in the dash as I didn't really go there at all, so nothing should have changed.
Starter connections look good and solid, don't see how that could've changed much in the few months it's sat parked in my garage.
Ideas would be awesome. Tips not only appreciated, but mandated. Thanks you lovely gents.
TLR my mother isn't proud of me, I keep trying though.
