2006gtmike
I have the inner portion of my FRONT tires wearing at a faster rate than the remainder of the tire tread.
Otherwise my tires are in really good condition.
I had an alignment done and the caster/camber/toe are all in "the green."
Would rotating my tires help out or what would be recommended?
Maybe my wheels/tires are out of balance?
I have found that my car has more body roll and just seems sloppy and not as precise especially in the front. I feel more bumps through the vehicle and seat. On sharp turns I notice tramlining. The wet weather traction is even worse than normal.
I'm being told by the alignment tech I am experiencing a little bump steer as well.
I had my struts replaced and brand new GT500 front control arms installed and that didn't help address this issue.
I have no clunks or sounds in the suspension.
I have tried adjusting my Koni shocks and struts to many firm and soft settings but no luck there.
I have tried each of the 3 settings on my front swaybar and have found the middle setting to be the best.
I just don't want buy brand new tires if it's not necessary.
