Experience the UPR Difference: 05-10 k-member
Ampire
3 valve
Maryland
I am thinking about getting one of these in a few months. Is the strength of the UPR K member comparable or stronger than the stock K-member?
Do I need to change the transmission height/mounts if the engine sits lower?
Would it be a good idea to install headers while I am doing the K-member?
Thanks.
Greg Hazlett
Stepping on the Pink Bus
Official Vendor
Chesapeake, VA
YES to the header install while doing the K member!!!
It is stronger than the stock stamped metal.
It will adjust the height at the most 1/2 inch which will not affect anything else.
Sharad
Site Sponsor
Fort Myers, Florida
can someone pm me the code? motor is out of the car after stroking it to 302, figured might as well do the K member looks like its a lot easier to do now then later...also has anyone weighed them ? like the stock vs. upr?
PM sent.
will the hellion kit work with this or do i have to modd the piping. i also need the discount code.
I know one of our customers has a turbo with our k-member kit, and he said it was tight in one spot. I can't tell you where, or with whose turbo kit. In most areas, our k-member kit has more clearance than the factory unit.
Greg Hazlett
Official Vendor
Chesapeake, VA
It was Jeremy (Lightblade) who had the issue with the turbo piping going through the A arms....pics were posted with it, do a search for his posts and you can see where he had the issues.
