I'm working on adjusting my tune and I'm noticing allot of knock under lower load in the 2250-3500 rpm range. The knock really only appears to happen when i'm between .30 and .40 load. I know having long tubes can sometimes give you some false knock readings and i've heard that superchargers can do the same thing as well, so i'm kind of leaning towards this for my knock issue in this particular area. Of course i do see knock in a couple of other areas but it's more of a single spike during WOT tuning not a constant pull of timing while cruising and maintaining speed.
So, basically i'm wondering if there are any known false knock areas on the 3v, or if there is certain areas that i can just not worry about knock and only really worry if it's above a certain rpm or something like that.
Any help is appreciated.
Thanks, Larry
Thanks, Larry
