Rob@Evolution
FB Performance Transmissions 4STB-E - $2,400.00
Pro Street/Strip (4R70W/AODE) - w/EOD & L/U (Ford MOD Motor)
Maximum HP Rating: 900
Maximum Torque Rating 750
Gear Ratio: 2.40/1.47/1.00/0.67
The transmission has never been installed or used. The customer decided to go in a different direction. Their loss is your gain.
• Built for hi-performance Pro street vehicles, late model Mustangs, Street rods and limited racing.
• Easily adapted to most rear-wheel drive vehicles.
• OEM electrical wires & connector are retained for electrical functions
• Full-manual "forward" shift pattern - only.
Features
• Quick Shift Operation
• Forward Shift Pattern only
• Hi-Capacity Filter
• Improved Oil Circulation
• Hi Performance Clutch Packs & High Energy Band
• Large Servo Assembly
• Solid 300M Direct Shaft
• Competition Hi-flow Manual Valve-body & High Pressure Regulator
• Overdrive/Lock-up
• Modified Front Pump Assembly w/Teflon Rings
Features
• Overdrive/Lock-up
