bakerjd
Resident Bum
Not bad for my 2nd time out (have only made 1 pass previously in my life). At least I was consistently bad, lol. Was spinning off the line going from idle. Probably could have let out some air from the rear tires and been fine but I've got plenty of time to figure it out. Was good getting a baseline for improvement. Trans is auto.
My mods include:
Kook's Headers (1 5/8") with catted-x, 4.10 gears, JLT CAI, Dyno tuned @ Street Lethal Performance, Pypes Pype Bomb Axle-back Exhaust, FRPP 62mm Throttle body, Hawk Performance HPS Brake Pads, DBA Cross-drilled/Slotted Rotors, Steeda HD Strut Mounts, Steeda Sport Lowering Springs, Koni Sport Adjustable Shocks ("Yellows"), BMR Adjustable Panhard Bar, BMR Billet LCAs w/Relocation Brackets, BMR Adjustable UCA w/Mount, Steeda Bumpsteer Kit, Steeda Adjustable Front Sway Bar End-links, Steeda X5 Balljoints
I had the Koni's set as follows:
Front: Full soft
Rear: Half turn from full stiff
Rear tires are Nitto NT555 275/40-18 (32psi)
Realistically, I'd like to break into the 12s and go from there. Thinking DSS one piece, Axles, MT ET streets, and safety loop + seat time should do the trick.
Also, I found it strange that they had both lanes set up so that you couldn't avoid the water box. I thought it would be better on street tires to avoid that but like I said, not very familiar. Any help is greatly appreciated guys.
