FML: What do I need to replace? Hit Curb -.-
Nyx_Maelstrom
First three are the side that I hit. I hit the curb at around a 20 degree angle, going 10-12mph.
Nyx_Maelstrom
Forums are fast today. Im going to get the car looked at, but thats all that seems to be wrong. Tie rod/alignment?
JEWC_Motorsports
S197 Junkie
Texas
Who knew they had an inner tie rod. learn something everyday lol.
You need to replace your eyesight and your driving ability...with the auto t1-thousand model... lol
For future reference as well, it's FTMFL
I wouldnt try to fix or replace stuff yourself here. Take it in and have ford look at it.
KillrStang
Texas Grown
Bryan, Texas
inner and outer tie rod. then take it to the alignment shop and they'll be able to tell you if the lower control arm is bent (not likely). just had an H2 here at the shop that did the same and he even had to replace the wheel bearing
Nyx_Maelstrom
Looks like a new steering rack is gonna be needed.
I would hope not >.> ...
Already replaced it with the T1000. Hopefully it can melt ice. I was going to take it to a performance shop that specializes in mustangs, preferably keeping dealerships eyes off this. Definitely not going to use the stock parts. Btw, FML = fuck my life
Thanks, I figured along those lines!
Good call, on the fml lol. Yeah there is usually always unforseen damage with these kinds of incidents. In my old mustang I spun out in the rain and hit a curb at about the same speed. And I bent the rim, damaged the wheel bearing, bent spindle, control arm, ball joint busted, warped rotor, list goes on and on. Might be a pricey accident....
Nyx_Maelstrom
Um i would actually use a stock tie rod... in some cases factory is better than aftermarket
Alright. I limped it about 30 yards then had it towed to a different spot. Made no sounds or anything, and with the windows rolled down at the time of accident heard no sound at all except me jumping the curb. The only thing is the car pulls to the left now.
Yeah im dreading it. Ive set aside about 3 grand just in case.
KillrStang
Texas Grown
Bryan, Texas
If you look at the picture of the tie rod. the piece that is like a threaded arm into the steering rack is the Inner. the piece that is connected to the spindle is the outer
Beef Supreme
va beach
Better to have a shop or someone who has suspension experience look at it. If it bent the inner tie rods that bad, it might have damage to the control arms that throws caster off, as well as possible wheel bearing damage. (for starters)
WytHorse
How do the wheels look? After a hit like that, any cracks at all?
