For sale Burnt Piston Built 3v Longblock.
Status
Not open for further replies.
n/a3valve
For Sale who would be interested in my 'Hurt' 2008 John Tymensky Built 4.6 3v Longblock.
Okay here is a quick run down . The engine is a 9.1 compression Longblock. It has a 8 bolt forged cobra crank. Manley rods and diamond Pistons. All arp hardware. Head Studs Arp 2000 rod bolts. etc. The engine also has comp poweradder cams and comp springs along with vct limiters. All assembled by Tymensky.
The cams are Comp stage 1 blower cams XE264ph-13 with the required springs and phaser limiters.
http://www.compperformancegroupstor...ode=CC&Product_Code=127450&Category_Code=FORD
The car made 665rwhp through a 4r70w but here is the problem "pump gas" . Causing it to burn/damage the number 8 piston. Worst case scenario would be to resleeve the #8 cylinder and pop a piston in and go. Or use your Block. and move everything over
Also I have the diamond piston spec sheet to help you get the correct piston from diamond or tymensky if you would rather just have a local machine shop do the work.
So on to my main Question, who would be interested in a fully built but 'hurt' 2008 3v longblock from powdercoated valve covers/timing cover to oil pan.
Due to family and bills I feel the best thing for me to do is to sell my whole setup and put the car back to stock and concentrate on more important things (family). And set the hot rodding aside for when the economy straightens out and I can really afford it.
I would be looking to get $3000 Over $6k invested Located in Ocean Springs, MS
Here is a pic of what she looks like minus all the pulleys. I currently have her crated up and ready to go and will snap a pic in the A.M to follow the new rules. But here is what she looks like. Will have updated pic in the A.M Thanks guys.
Also i have gotten a Pm as to how do i know that it burnt a piston. well we did a compression test and #8 was low . So a buddy of mine that works for a dealer brought home a Digital Scope/camera and we went down in the hole. and you can clearly see #8 has a hole in it.
Text/call (228)219-0084 For faster service.
Here is updated pics. But i will be taking off the pulleys. And water Crossover Thanks.
VTXFrank
Obama SUCKS!
Santa Rosa Beach, FL
Someone didn't read THE RULES.
NO "Feeler" threads are allowed. For Sale with a price, location and a picture of the item with your screen name, location and date is required. This thread will probably be locked or deleted here soon if you don't fix it.
PM a mod when you are Ready to update your post in compliance with our classified rules
BossBob
Questions
1. Stock bore and stroke setup?
2. Anything done to the heads other than the cams/springs/etc?
n/a3valve
The stroke is stock . the bore is 3.5720 according to my piston spec sheet, which i believe is stock.?? and nothing done to the heads. just cams, springs and limiters. no port work
PNR Welding
Hammonton, NJ
Those are a .020 over pistons. Standard bore is 3.552. So it would need a piston for a 5.933 rod and 3.572 bore.
Steedman07
Classified's Moderator:)
Connecticut
If you are interested in buying this, then fine. But leave out the BS posts about how much he asking. Thank you
Status
