For those with 05-09 that have changed clutch line
Phil1098
Central Illinois
I'm considering changing the clutch fluid line and with the A/C lines right in front of the clutch master cylinder, how do you get to the fitting? I already know the one near the transmission is a bitch, but the the one at the firewall I don't see how I can get to it. The FRPP instructions only show a later car with a sound tube. The A/C lines aren't even there. Can't find pics, youtube vid, nothing.
Doug M
Fast Cars & Freedom
AL. Baby
Same problems! Lol
Sent from my SM-G920V using Tapatalk
Phil1098
Central Illinois
I just looked at the car again and it looks like you can remove two bolts and lift the receiver/dryer up and out of the way giving you a clear shot. Don't know if this is right, but it sure looks like it is.
skwerl
tree hugger
central Florida
I was able to work around it on my 09. Huge pain in the butt. I'd show a picture but Photobucket....
RocketcarX
95% of my weight is fuel
Colorado
I did mine without taking anything else out, it's been a while though, lol.
Doug M
Fast Cars & Freedom
AL. Baby
I have a small pick, and I still can't get the thing off. I just gave up. Lol
Phil1098
Central Illinois
I'm not too concerned about getting the clip out (maybe I should be), more concerned with getting a rag right under the fitting and not spilling brake fluid on the painted surface right below.
BruceH
BBB Big Bore Boss 322
As I recall I needed to unbolt the whole pedal assembly to get access to the clutch master cylinder and line.
In the end I went back to the stock line. IMO it isn't the line as much as it is the master cylinder. Think about it, the stock line is very hard plastic while the replacement line is braid covered rubber.
If you delve into the situation deeper it comes down to the pressure plate and how much travel is required to move the clutch fast. In my case it was something as simple as using lube on the input shaft splines prior to assembly.
Doug M
Fast Cars & Freedom
AL. Baby
Thats why we like you Bruce, always thinking ahead. Lol
