Front Crankshaft Seal differences
SVT Rider
Portland, OR
This is actually the part number for the factory 3v 4.6 seal. Does anyone know the part number for the larger diameter hub?
My apologies for the confusion. You are correct that the part number I gave is for the stock 4.6L 3V OEM seal. I agree with Marble, you will need to contact Innovators West for their recommendation on the part number for the larger seal.
05stroker
Never enough power guy!
Bullard Tx.
I don't have have it but if you call IW I'm sure they would take care of you or just sell you one.
I just saw your request this morning and my invoice from my purchase odd long gone...good luck!!
There's is not a Ford seal though and thats what Im hunting. Thanks for the response though.
05stroker
Bullard Tx.
I may have to run there seal, I could have sworn at one point I had found a Ford seal to do the job though.
05stroker
Bullard Tx.
Actually I put the sealant on the back of the washer so it seals the keyway and the front of the crank to the balancer as well.
