FS: CT: Black Steeda Pentar 18x9.5 5x114.3 Wheels
Kylar
CT, USA
Ford Mustang Black Steeda Pentar 18x9.5 5x114.3 Wheels They are 2005-2014 offset
The Wheels are in good shape, no bends or vibrations. They are Gloss black, in the pictures one wheel is missing the center cap, I do have a new center cap to replace it.
Steeda Pentar Details
Awesome looks and great handling, Steeda's exclusive Pentar wheels feature a split spoke, track tested low pressure cast design. Low pressure casting produces a stronger, lighter wheel than traditional gravity casting methods. The Pentar wheel was designed with the correct offset for your Mustang and to fit larger brake kits that most other wheels will not clear. Want to put more rubber on the road and be able to fit big brakes? Steeda's Pentar wheel is the answer.
Low Pressure casting for light weight and track tested strength
Will fit Brembo brake packages
Awesome looks designed specifically for your Mustang
These wheels alone were close to $1,000 new, Asking $SOLD (Lower 48 U.S Only)
Paypal or Cash pickup only
No Trades
Speedboosted
Found missing cylinders
PNW
Do you know what the actual offset is and how much one of them weighs?
Kylar
CT, USA
Not sure on weight, but i know they are pretty light for the size.
Specifications:
Finish: Black Gloss
Offset: +45
Hub Bore: 70.0mm
Bolt Pattern: 5x4.5mm
Front: Yes
Rear: Yes
Fitment:
2005-2014 Ford Mustang GT V8
2005-2014 Ford Mustang V6
2007-2014 Ford Mustang GT500 Shelby
