Fuel line upgrade hat to rail with PPRV delete kit - $225
krang00
Allentown, PA
Fuel line upgrade hat to rail with PPRV delete kit - SOLD
All 8an aqp startlite lines and fittings/hose ends. The Fore f10 filter is new with the reusable stainless steel element and orb to 8an fittings to plumb it in, all e85 compatible. At the hat it has the oem style quick disconnect fitting installed and for the rail has the larger inner diameter efi fitting. This setup is ready to go on and easy to install using the stock line routing and filter mounting location. Will drop duty cycle 20%+ depending on setup.
Info on the Fore filter and ss element.
http://www.foreinnovations.com/product_p/16-900.htm
Excellent upgrade and price here! This exact setup dropped pump duty cycle 26% on an e85 car at around 600hp.
