I have a dual pump division x return fuel system. The car drives great when the fuel pump comes on with the ignition and has never died while driving. I noticed after driving I will go to turn the car off and when I go to turn it back on, the fuel pump will not come on with the ignition(no priming or running). There are zero fuses blown, fuel pump relays are good, but the aux fuel pump relay will not come on. I bypassed the inertia switch to make sure that’s not the issue. I disconnected the negative terminal from the battery and reconnected it and the fuel pump comes right back on with ignition. Each time the pump doesn’t come on, I disconnect the battery and reconnect and bam it’s good to go.. Any ideas? I’m stumped.
Edit, FPDMS are bypassed, all the wires are cut except the two middle ones that go to the PCM
