Gauge advice
Dennis Thomas
I’ve got a 09 GT with Edelbrock supercharger and Detroit rocker cams and need to pick up an boost and afr combo gauge. Any suggestions? Lots of different brands with mixed online reviews.
Bingo
Because street car
Phila, PA
I like my Autometer Sport-Comp AFR and boost gauges.
svanur
Iceland
I like AEM 30-4900 wideband failsafe gauge. Both boost and afr with the ability to adjust what and how it displays.
Dennis Thomas
Cool, I ended up ordering Innovate PSB-1 PowerSafe Boost and Air / Fuel Gauge Kit. Any advice installing on a s197. Guessing, vacuum hose and the other by replacing one of the o2’s
and plug it in. Will I need any adaptors or anything? Last car I installed gauges on was my 66 GT and it’s been awhile
MrAwesome987
Upstate SC
I would not suggest replacing any of your factory O2's. The front 2 are needed for tuning, and the rear 2, if messed with, will throw a check engine light (unless disabled in the tune). Even if they were disabled, I wouldn't put my wideband O2 that far back in the exhaust. Best practice is to weld in a new threaded bung for the new O2. Any exhaust shop should be able to do this if you can't do it yourself.
Your intake manifold should have a place to run a boost gauge off of. The wiring for the wideband should be pretty well described in the instructions for the gauge you purchased. For +12v, I tapped into the cigarette lighter on my car I believe. The one above the radio.
Dennis Thomas
Thanks for the advice. I was totally guessing on replacing one the the rear o2’s, glad I asked now. What you said totally makes sense. I’m installing to finish up a tune. Gives something to think about while I wait for the gauge to arrive. Thanks again guys
