Gears
StageMe
Pasadena, MD
Hey guys well it looks like along with the new headers, wheels and tires, and upper strut mounts it looks like I am going to be putting in some new gears... What I am wondering is what install kit do I need to buy? I see there are several different options with each level of kit containing something different. I just want to make sure that I get the right one so I have everything I need. Also any suggestions for a good strength cover?
rojizostang
i love my cams
san antonio, texas
install kit?
gears, gear oil, friction modifier (maybe, depending on the type of gear oil) and a new pinion nut should come with the gear set, and a crush sleeve. any shop that does a lot of installs should be able to tell you if you need anything else.
what all comes in an install kit? bearings? seals? unless the stuff you currently have in there is no good, you shouldn't need to replace any of that stuff...IMHO
07 Boss
Sin City
Stronger, has drain plug, looks nice (shiny and stuff), & FRPP (can't go wrong).
