Gen3 coyote swap in 2005
catsvamp
Ohio
Hello Everyone,
I am doing a gen 3 swap in my 2005 V6.
I am a little confused with the control packs for the set up I am doing.
The control Pack i am looking at is M-6017-M50BA.
But i do not need the wiring for the transmission as i am not the 10r80. I already have a "built" 6r80 that i was planning on using.
Any advise would be great.
Almost forgot i am using the Holley instrument cluster in place of the OE.
mattjames
That control pack is for a 10R80 along with the ECU. There was no Gen 3 controls with a 6R80 so you need a manual trans control pack with a US Shift controller or equivalent
catsvamp
Ohio
I started to figure that out this morning when I got in to work. I had a convo with one of my customers about it and he said i should go that route also.
Thanks allot.
rocknrod
Wake Forest, NC
Not sure if any of these will help or not:
mattjames
That’s actually my harness. Only works with a gen one ECU so all the gages and cruise and ac work. He’d have to do a 3-2-1 setup to use a gen one ECU to use the gen 3 short block
catsvamp
Ohio
Well thanks again mattjames. This build is going to take longer now damn vet bill wiped out the cards. :(
