I bought GI Joe's heat exchanger for him since he's going turbo and parted out his old blower setup. It's the one from Gordsford, and I was impressed with the quality. Lightweight, aluminum, and THICK, much larger capacity than the stock unit. Had to drill a couple quick holes to mount the brackets, but it wasn't bad at all.
The only trouble we had was connecting the pump outlet with the inlet on the H/E. They are so close to eachother, the hose would bend. So we went up to Lowes and went to the plumbing section and looked around, and found these brass 90 degree fittings. They are ribbed for good grip, but we added some worm clamps for good measure. I included some pics of our solution so you can see what the fittings look like.
Oh and While the bumper was off, I also put in some clear running lights.
