Great deal on some quality LCA's.
BMR Tech
Traction Vendor
Tampa, FL
Just a heads up, that design is about the weakest possible way to make and adjustable LCA.
Attaching (welding) a small thread to a large housing, is not a good idea.
avinaj80
Oh, you've had a set of these break? Not a good buy then?
MassMustang
Southeastern Mass
For the price, you're MUCH better off buying a quality product from BMR. I wouldn't trust the ones you found at Amazon.
If you're looking for a deal, find some used BMR LCAs. My GT500 LCAs work fine for my minimal mods and someone let me have them dirt cheap.
avinaj80
I can see where SPC's design may be "inferior" to other designs. But, it would take a whole lot for the welds on those arms to give out. I was trying to get more info from Kelly in regards to this type of LCA's design flaws. I know welds break under harsh abuse, but I know SPC does not make garbage.
BMR's products are top notch, no doubt. I'm running the adjustable panhard and strut tower brace. There are also other manufacturers that make quality parts at a decent price. I myself cannot really afford to shell out $250+ for a set of adjustable LCA's. But $150 for something that I know will hold up well? Can't pass that up.
skwerl
tree hugger
central Florida
Why would you put adjustable lower control arms on your street car? In several years of reading and discussions I have yet to see a single compelling argument for using them.
avinaj80
Planing on using them for another ride I picked up to beat up at the track.
rojizostang
i love my cams
san antonio, texas
i have adjustable lowers. for one thing, if you've ever measured the distance from wheel center to wheel center, front to back, you might be surprised how much difference there is. adjustable lowers allows you the ability to dial in the distances precisely the same, along with still giving the ability to adjust pinion angle.
obviously you don't need both to be adjustable, upper and lower.
Mineral_'01
I am assuming this is only an issue once someone adds relocation brackets into the mix. I do not see those dimensions being very far off with the stock axle mounts and fixed LCA's.
Unreal
Gilbert, AZ
Saving $100 on an item that can land up causing a safety issue, wreck, and other damage is just silly.
fdjizm
Drag Queen
NY/NJ
Don't see a real reason for adjustable LCA's better be good at measuring shit.
avinaj80
I'm surprised you have allowed rust to show on the diff Darren... Your falling off man...
avinaj80
I just don't like that design, at all, so I thought I'd share. I mean, I don't really care what brand people use at the end of the day, I atleast want them to use a good design.
These LCA appear to be the same as the Eibach. A quick search and:
http://forums.corral.net/forums/s-1...a-owners.html#/forumsite/20549/topics/1426669
And shit... That was a compromised weld for sure. in our opinion, is just a set of fixed LCA's and and adjustable UCA decent for a road course car?
rojizostang
i love my cams
san antonio, texas
mine was off about 1/2'' from side to side before relocation brackets. I'm the only owner and the car has never been wrecked, other than hitting a deer which was minor damage.
the other thing is lowers are easy to get to to adjust.
BMR Tech
Traction Vendor
Tampa, FL
What I recommend is, find out what your thrust angle is. If it is between .25 and -.25.....then fixed LCA is fine. Anything over that, I recommend (although not "needed") having adjustable LCA to dial it in and square it up. But typically, yes, what you asked.....fine for most applications.
Happens all the time. We test a lot of parts on local cars (and of course our own) and we see 1/4" or so variations quite often. 1/2" is a little more rare, but I have seen it.
I recently had a customer bring me his car, with only lowering springs installed. Axle was off 3/8" from side to side. (wheelbase)
rojizostang
i love my cams
san antonio, texas
I've had this conversation with guys before on here about adj lowers and everyone thought they're a waste of time. At least you are able to confirm that there is frequently cars with wheelbases that are off. Thanks.
