Grey Mare S197 Turbo 3V Holley Terminator X Max
ponys197
Troy OH
Final dyno run before I took it to get the 8.50 cage installed. Decided while it is there to have Jason convert the exhaust to a 4" bumper exit as well. Will put it back on the dyno after that.
495 HP / 505 TQ on 14.3 psi (10 spring / 5 psi dome commanded) on a non-lockup converter
FYI this is an unopened SBE 93K mile 4.6L 3V.
ponys197
Troy OH
Part of that is the Holley requires cams to be locked and being on stock cams right now with no way to adjust they are at full advance. We have timing pulled out as much as we can down low to limit torque.
It has lived so far and I recognize that at this power and boost level it could let go at any time. - and I am okay with that.
This engine has seen some work and kept asking for more.
We are doing everything we can to make it live and try and get a shot at least a 10.2x timeslip .
Mustang dog
Any updates on this build? I’m curious how you’ve been able to make the termi x work? Is it stil dbw? Or cable throttle?
