Grille emblem question
Firefighter46
Roscommon, MI
Does anyone know if this larger grille is a stock part for a 2013 V6 base model? There are no engineering marks or numbers on the larger of the two, or upper grille. Nothing, nada...
The reason I ask is because I'd like to find an emblem for it, specifically the three bar, running horse emblem that usually sits off to the driver side of the grille.
Does anyone know of a source or part number for one that might work?
Thank you,
Alan
JimC
That is similar to the OEM both the MCA Edition grilles and the GT/CS grilles, but it is not the same. For the MCA the color is different - silver, this looks more like the GT/CS black. The other things is on both the OEM grilles, the upper grille has a spot embossed for the pony on the driver side and there is no embossed area to insert the badge. (if I can find a picture of the MCA grille that came off my 2013 I will post it)
So my guess is these are aftermarket copies.
You will have to figure out the best way to mount your selected badge, but you can put whatever badge style you want since you aren't limited.
Edit: I was wrong, found a picture of my old MCA grille and other than color, the upper looks like this one. Must have been my 2017 grille that had the embossed area for the pony badge:
Firefighter46
Roscommon, MI
Sorry for the very late reply, but my front end parts are supposed to be getting painted this week. Do you know the part number for the emblem on the grill of the pic you posted? That's more than likely what I'm looking for.
