H & x-pipes.
GONE_N_60
The Bad Guy
Las Vegas/Chicago/St. Paul
These were my dyno numbers (avg):
Stock H with cats 297.75 RWHP, 308.25 RWTQ
O/R prochamber 301.5 RWHP, 304.15 RWTQ.
Prochamber w/hi-flows 304.15 RWHP, 312.3RWTQ.
Do you think the increase with the Hi-flows was due to an increase of back pressure?
I want to get a Pro-Chamber to go with my Mac BoomTubes and I was debating whether to go catted or not.
Gray Ghost GT
Road Racing Fanatic!
Madison, AL
If your thinking about getting longtube headers down the line then you should wait on getting a new x/h pipe because once you get the longtubes you will need a shorter midpipe to hook up to them. Thats what i did and it sounds amazing, and has the extra hp from longtubes.
I agree. If this H or X pipe is for sound only with a set of loud mufflers, fine. However, if you goal is to achieve an increase in power and torque, as well as good sound, then save your money for a set of long tube headers, which often come with their own H or X pipe (catted or O/R).
gmantheman
Escondido, CA
It may be because of the back pressure. I would go catted prochamber, but hi-flows not the prochamber that splices into the stock cats. The O/R procamber with boomtubes might be too loud and it will trumpet at certain RPMS. The splice in prochamber, from what I have read, will be a little deeper but a little quieter than the catted H pipe. Prochamber with hi-flows is a good middle of the road set-up. Louder than stock, yet only slightly quieter than the O/R set-up. It will also produce a deeper tone than the O/R.
GONE_N_60
The Bad Guy
Thats exactly what I was thinking. Thanks for confirming that. What Hi-Flows are you running. I read decent reviews on Basanni Hi-flows and Magnaflows.
J.Cagle
Dennis Kansas
I wonder how well itd add power if I had a set of hi-flow cats welded in place of my stock cats. You think itd be worth doing?
NastyStang113
Made in U.S.A.
Central Florida
A offroad mid pipe is worth about 5-6 rwhp. The gains between one or the other are very little and not really recordable. Can't really account for 1 rwhp..
808muscle
Maui
Do most people run an axle back with it or a muffler delete?
Good question. I am looking for a good... ie cheaper substitute for LT's to improve sound. Not wanting to spend the $ or have the hassle of a driveway header install. I currently have spin tech mufflers with an xpipe, but I am wanting more.
patrick
Ricosbullitt
I noticed that some catted x pipe come in pieces and im wondering if they can later be spliced in with long tubes?
gmantheman
Escondido, CA
If it's an o/r prochamber I would run axlebacks. Straight thru and chambered would work. Even though the o/r prochamber is a little quieter than an o/r h or o/r x, muffler deletes may still be too loud.
Ricosbullitt
Anybody? I was thinking of getting the bassani catted x and it looks like I might be able to use it later with long tubes?
