Hampton Roads, VA - The Hangout!
Aandf1978
M90 SUPPORTER!!
Virginia Beach, VA
Isn't it the case that, say if I were to drain all my oil out and then dump this royal purple in, that from there on out I would need to stay with full synthetic for oil from now on?
I know this used to be the case and I just stuck with that, has that changed?
Fallenauthority
La Plata, MD
Yes. That theory is now a crock of crap. You can put synthetic in then go back to regular oil next time.
808svt
I could be wrong but I believe that was for older stuff with cork gaskets and the possibility of leaks when switching back.
rayS197
virginia beach, virginia
His cell doesn't even have his voice like it use to for leaving a message. It just goes straight thru. Hope they are ok.
retfr8flyr
The Old One
Providence Forge, VA
The last time I got hold of him was in Nov. He told me everything came out fine with his wife's surgery and they were doing fine. I have tried several times to get him since and have never gotten a response. I hope everything is good with him.
Earl
mds08
Anyone local have a front pass.side lower control arm they wanna sell. My Uncle has an 05 GT with 14K miles and its gone bad.
mds08
Yes, the ball joint. We just replaced the sway bar bushings. While the car was on the lift the pass side wheel had some play. This was a problem on the 05 and 06's
Greg Hazlett
Stepping on the Pink Bus
Official Vendor
Chesapeake, VA
Ugh....I know they are not cheap from Ford...think they were around $300 each when Jeremy had to replace the BMR's after they cracked.
mds08
Yea they are expensive. I can get parts wholesale dealer cost at local dealerships. Keep that in mind if anyone needs anything. I'm looking to find one local used, of course Ford has to order this one. The stock lower A arm is not bad, very little play in it, drivers side is tight. I can get a new one for about $150. I think there is a TSB on the 05 and 06's for this problem. They have seen brand new cars with bad control arms with 5 miles on them. I'm looking to buy a new 5.0 soon. Gotta sell my 93 5.0 first.
06gtimpact
Spotted a GO Parnelli Jones last night, great looking car first time I've ever actually seen one.
