Kevinmach1
Major Member
Has anyone gotten this code P0456? < Its says emission evaporator system leak (small leak detected).
What does it mean? What's leaking?
with the engine running could conceivable cause this code as well or if the cap wasn't properly tightened. Any of the following could also be the cause:Bump. Just got this code. Can it be caused by not tightening the oxygen sensor enough and it causing a leak? (front driver side).
I pulled my longtubes and put my stock manifolds back on over the weekend. I forgot to put the o2 sensor on the driver side one before putting the manifold on the block. Only way I could reach from the bottom was enough to barely hand tighten the sensor.
Also, could a leak in the connection between the stock manifolds and midpipe cause it as well? I couldn't find my damn stock nuts that go on the exhaust manifold studs so had to go buy regular nuts at lowes to hold it together until I went to ford and bought the stock nuts (which I think are locking) just now after work.
Haven't touched the fuel system at all. I'll check the cap and see if there's anything wrong with it. Where do I get it smoke tested in case I have to? And rough estimate on how much it costs?
I had the same problem and I fixed it, one of the hoses was unplugged on the drivers side on the black blob thing, check there
