Ok after doing alot of searching the past 2 weeks about header installs I started mine this morning. I am 6 hours into it and dont even have one manifold off yet. It is mostly because I havent went to get a 13m ratchet wrench. But my questions are how is the dip stick removed. Do I just take the bolt out of the bracket and pull? Also I dont have another jack to jack up the motor and so Im trying to do it without. Im only doing shorties. I cant seem to get to the bolt on the passenger side second one back. Can this be taken out without removing the mounts. Also if I end up needing to move the steering shaft. I take the 2 bolts out on the rack and the one at the top of the shaft and pull and it should come out right. I read that if the steering wheel moves it can mess stuff up. Do I need to mark any thing when removing the shaft? Also if I end up needing to jack the motor up then how do I do it. Where does the jack go and do I take all bolts out of the mounts and just remove them. Also I was looking I have a strut tower brace so this would need to be removed and my car is already on jack stands can I take the bolts out of the top of the brace without the front suspension falling. Sorry for all the questions but this shit is hard by myself. I have gone over both of the write ups on this forum but both Have different ways of doing it and not all info I need is covered.
that changes everything..... My bad as well.
