darrens07gt
Let me start by premising this with what has been done recently. One week ago I installed hot rod cams and a Brenspeed 87 tune. The car drove fine and the cams sounded good. I ran the gas down to 10 miles till empty and then filled up with 93 octane gas and loaded the Brenspeed 93 octane tune they had sent me. I drove the car all week (500+) miles and the car ran great with only two minor exceptions.
1). The car threw a code related to a delay in an 02 sensor which was LT header related. Brenspeed is making a tweek to my tune and will email it to me shortly. I deleted the code and it hasn't returned.
2). All week the car ran fantastic but I noticed that when I was coming to a stop in neutral the idle would surge between 400 and 900 rpm's. Once I actually came to a stop the idle would settle at 750 rpm's and stay there. I talked to Brenspeed and they said it was most likely caused by a dirty throttle body. They recommended that I watch their throttle body cleaning video so I did.
Now on to what happened yesterday. I pulled the intake hose off the throttle body and then removed the throttle body from the manifold. Using a rag and throttle body cleaner I bought from NAPA I cleaned the throttle body which had indeed been filthy. I re-installed the TB and hose and took the car for a test drive. Sure enough the surging issue went away and the car was driving absolutely perfect.
About two hours later I went to a store about 12 miles or so from my house. The car ran great the whole way there. I headed back home and had gone about 10 miles when suddenly my car died. I tried to re-start the car but it wouldn't even try to start like it wasn't getting gas or spark. At first I thought maybe I ran out of gas because I was 25 miles to E when this happened (I was going to run it low and top it off one more time to be sure all 87 octane was gone).
Then I discovered the car would start right up IF I turned the key to the off position for a few seconds first. I got up to 30 mph and the car died again. I turned the key off, waited, re-started and got up to 30 mph again. The car died again and I rinsed and repeated until I got to the gas station where I put in five gallons of 93 octane. I was hoping that would fix the issue but it kept doing it and I had to limp it home the last mile doing the same rinse and repeat I described above. When I got home here is are the codes that were thrown:
P0010: A camshaft position actuator control circuit / open bank 1
P0020: A camshaft position actuator control circuit / open bank 2
P0102: Mass or volume air flow sensor A circuit low
P0135: 02 sensor heater circuit bank 1 sensor 1
P0155: 02 sensor heater circuit bank 2 sensor 1
P0443: EVAP system purge control valve A circuit
P0446: EVAP system vent control circuit
I gotta think this has something to do with the recent cams/tune or more likely the throttle body cleaning and re-assembly. Did I screw something up? Anyone have any idea what's going on with my car right now? Any insight would be greatly appreciated.
