Help me chose 15" drag tires coyote 6R80
skaarlaj
Probie Former Pink Bus Rider
Hello all, my current Hoosier quick time pros are down to the chords, so I'm needing new rear 15" tires for the drag strip. I've had good luck on Hoosier quick time pros, and bias ply slicks on this coyote mustang and a nitrous assisted 03 Lightning I had in the past, but keep hearing good things about drag radials. Here's what I've been looking at so far.
I'm also open to suggestions, also have centrifugal blower an 245mm 5C stall converter in the car fyi. Thanks in advance
skaarlaj
redfirepearlgt
BMR stuff. LCA's, UCA, Relo brackets, Panhard, BMR Drag springs for GT, Lake wood 50/50's rear. Just added Strange Front single adjustables and BMR GT500 Drag Springs up front this spring. Cut 1.62 best last year on ET R series 305/45/17's with full stock front end. Everything is poly bushing BTW.
skaarlaj
Right on man, glad it's performing good for you. I might just start off doing a spherical / solid housing bushing on the stock upper control arm, and possibly the most streetable anti-roll bar from BMR, and see how that does for a few outings.
redfirepearlgt
Sounds good. I use mine for more than cruising and racing or I'd go with the BMR anti roll bar as well. Just drove it back home 3.5 hours each way over Easter weekend. Smooth quiet ride, and got 21.3 MPG avg, even with all of the hard passes on the two lane highway drive, and making a few fly by videos way out in the middle of nowhere in a 1/4 mile bottom while there.
