UltraKla$$ic
PERENNIAL WAXXER
Can you see into the cylinder or is the broken piece lodged in the hole?
/\/\/\/\ This
If you can't see in the hole then you may be able to tap it out. If you CAN see all the way down in the hole and into the cylinder................................good luck tomorrow with the scope.
