SlowMo
Oklahoma
i have a 2013 mustang gt with the track pack.
I did and auto trans swap in it with a 2014 trans and trans harness. Evidently the TRS is different between 2013 and 2014. I am looking to repin the wires on the pcm side that are in the wrong spot now for my 2013 auto trans pcm. Im getting a few codes when I test the pcm with forscan. One being PRND switch isnt talking to the pcm so it doesnt know what gear its in.
It wont crank. If anyone thinks its something else, I'm all ears.
myStang50
San Antonio, Texas
No sure if this will fix it. If the 2014 trans was worked on before the swap and the lead frame was replaced/repaired, the selector switch may not be aligned.
I read when relacing the lead frame on the valve body, the selector switch needs to line up with the switch on the lead frame.
