raredesign
Hey everyone. First, this has been a huge learning experience, so I appreciate how patient everyone has been with me and for this forum resource. It is fantastic.
I am in a jam at this point, as communicating via email is sometimes a risk where context can be mixed or conveyed incorrectly.
When I purchased the S&H Performance Single Turbo Kit, I went with the 70mm, and we had initial talked about 550-600rwhp on a stock block. After some back and forth with them, I decided on doing a built block, and that my goal would be more 700rwhp-800rwhp. Somewhere along the line, understandably with a lot that had been talked about, and with me being so new to all this, I ended up with 60lb injectors and a 405lph Walbro DIY kit. It was recommended that I use a boost a pump to push it more, but after talking to the actual supplier (not sure if I am supposed to mention the name), I was informed it would fry the pump because they are not rated for more than 14volts (actual 13.5).
I am hoping that will be sorted out, but I first need to better understand what I actually do need, and if it is possible to hit 850rwhp on a returnless system. I cannot afford $2400 in fuel system upgrades at this point.
Will a GT500 dual fuel pump from AmericanMuscle.com at $700 be sufficient?
Do you see how it gets confusing, when I have a 405lph that won't suffice, but the GT500 dual fuel pump is advertised at 375lph, so I can only imagine that is per pump, lending to 750lph total flow.
I don't plan on running e85, as that sounds like my mpg would drop significantly, and aside from trips to shows, this is a nice summer daily driver or weekend driver.
While I have much to learn, this scenario completely caught me by surprise and will hold up the build and I don't want to cause my speed shop any frustration.
Thank you all
Thank you all
