Help with my LCA clunking!
07Alloy
Clarion Pa.
I just installed bmr lca's part #tca022 along with relocation brackets. Brackets are welded in like they should be. I am getting this terrible clunking whenever I move the car. I havent drove it more than 20 feet or so. I have checked everything. Thinking of putting my OEM control arms back in. Any thoughts. Thanks
marcspaz
~Resigned~
Dude, there is nothing wrong. Those arms have hemi joints on one side and they make a lot of noise. it is completely safe.
I had the "Race" version installed in my car for about 8 months. They have hemi joints on both ends. It sounded like the rearend was gonna fall out any second.
EagleStroker
N/A Junkie
Memphis, TN
If you haven't changed your UCA, this can also be caused by the mount for it flexing. It was extremely noticeable before I changed my upper!
Ninjak
The Wolf hunts at night..
Hmm I been told that those are very noisy. So some of the responses here are good as well. Double check, triple check, and make sure its just noise.
I went with L&M LCA's and I have no noise or issues. So just keep checking it all out.
bigwilly43729
I do stupid shit, a lot
Oklahoma: Not terrible
Make sure you torque the bolts for the LCA at ride height or as close as you can get to it. A set of jackstands under the axle will take care of this. Otherwise, these things are just noisy. My rear end sounds like its going to come apart sometimes. No big deal.
*And it's 129 ft-lbs BTW.
FnSweet06
did you grease the polybushings? I accidently forgot to grease mine when i first installed them lol and was good for about acouple days untill i started hearing them. Went back greased them up & that fix the problem. Once in awhile it'll clunck when im reversing but not much. And mine arent welded
MexGT
Mexico
+1 on greasing them
and also if you have an UCA you NEED to buy the uca bracket, cause they tend to be noisy too.
Ninjak
+1 on the grease. It said to use generously and heh I did ! I lubed those suckers up good, hell I used the entire tub. The L&M had a very nice design to them, and the way they fit together and on the car, that lube is not coming of for a long time
2kanchoo
+2 on the grease, the proper torque, and the loud hemi-joints.
07Alloy
Clarion Pa.
I hope these things really arent supposed to be this noisy. I am going to double check the torque, but I pretty sure I did everything right. Did it at ride height. They are facing the right way. If they are going to be this noisy, I am going to switch back to stock.
2kanchoo
If they still bug you that much after you check everything you can sell them and get some that have poly bushings on both ends. It will still make a good improvement over stock but they aren't loud like ones with the rod ends.
07Alloy
Clarion Pa.
Well, I have the stock ones back on. I think I discovered the problem too. I got these used from someone and they looked to be in great shape. Well, I noticed when taking them off that it seems something it missing from one of the joints. I took a picture. New at this so not sure how to attach from my desktop. Stay tuned.
07Alloy
Clarion Pa.
Well. I thought I would bring this one back up. Still havent got the pic loaded here, but go to my profile pics and you will see what I am talking about. Half of the heim joint is missing. I bought these used off of someone on here. I am guessing they didnt realize this either. It doesnt look like it broke...just missing.
marcspaz
~Resigned~
Call BMR for parts. If not, I'll sell you my BMR dbl adj race arms cheap...
travelers
Eastern Pa
It looks like your missing the end link adapter.
