HID to Stock Headlights. PLEASE HELP!!!
08GTS
Austin
Ok, so my car has an HID kit installed in the headlamps, and the ballast on the passenger side went out, but I really want to just revert the lights back to stock. I live in Houston and everyone here loves blinding the shit out of each other with HID's. I looked at the set up and it looks like the stock connector was cut off and a new bulb assembly was spliced in. Does anyone know what harnesses I'd need to get? I've tried searching the internet and cant find anything. Thanks.
Mustang30212
Columbus, Ga.
You should be able to buy the headlight pigtail from Ford and just put it back on right?
If you want to replace the harness...it starts over at the fuse panel and goes across the front of the car. It connects to the turn signal bulbs...hood release...horns as well as the headlights.
I just pulled this harness out of my 05 to put in a set of factory HID's. Not sure it'd fit your car...but it should.
RH
