Lupo222
The front Pony is held with 2 stamped thin metal clips. The clips are designed to be pushed over thin plastic pins attached to the "chrome" Pony. Removing the pins means you'll snap the pins clean off. You'll need to remove the grill to see exactly what I'm describing. Or, you can gently pry the Pony from the front with a putty knife, screw driver, etc... (I would not advise this.). The easiest way is to remove the radiator plastic cover, reach behind the grill, break the pins, remove said Pony, and 3M tape it back on.
Good luck on whichever way you decide to go.
Gerardo
damn...after all that, i think i may just stick tape inbetween the grill and the pony and tape up some newspaper and spray it on the car!!
