matt texass
- Joined
- Apr 10, 2007
- Posts
- 1,958
- Reaction score
- 4
That sucks. 91 it is then.
So the stock pump won't support a 125 shot?
Wouldn't chance it buddy when you just get a BAP and never have to worry about it.
The reason you run a richer mixture is for a variety of reasons. The first is how combustion takes place in a nitrous motor is different than in a NA motor. Nitrous oxide does not burn, it is an oxidizer. It provides more oxygen, so more fuel can be burned, and the result is more power. The atoms in a nitrous oxide molecule are bonded together. At 565 degrees F, the bond is broken and the oxygen is then free. By adding nitrous oxide to an engine, the total amount of oxygen is increased and other gasses that do not support combustion (mostly nitrogen) are decreased. This speeds the burn rate and requires less timing advance for peak output. It is hard for many people to grasp gaining power with less timing, but it’s a fact. Peak cylinder pressure must occur approximately 20 degrees ATDC to make peak power. If you speed the burn rate, peak cylinder pressure will occur to soon. It is easy to run too much ignition advance with nitrous, but too much will not only hurt power, it can quickly bring a nitrous engine into detonation and destroy it.
This brings us to another reason you need more fuel in the cylinder. To keep the engine out of detonation, you must control the extra heat that nitrous makes. The easiest way to do this is to add more fuel. All nitrous systems come with rich jetting to give you a safe starting point. The extra fuel takes away heat and raises the detonation limit. If you don’t try to over do it, and keep the hp levels within reason, running slightly richer should be all you’ll need to control detonation. Running richer will both reduce the power output, but will raise the detonation limit to allow more nitrous to be used .
And last but not least "Atomization". You need a richer mixture to better the chances of the nitrous mixing with fuel. If a nitrous engine runs lean, it can destroy the engine in a matter of seconds. There must be enough fuel for the nitrous to react with, if there isn’t, temperatures rise rapidly. The oxygen that couldn’t react with fuel will oxidize any parts that get hot enough, and the next thing in line to burn is aluminum.
I am running 100 shot,the stock pump , with Doug`s tune. I ran a 12:1 at 5600 ft above sea level. Which is really good up here. Never run the nitrous in overdrive,or Traction control on. Check your leanest plug after every nitrous run. That should be the front passangers side. Run some 101 unleaded race gas with your highest grade that your tune is set for. Just my .02
ran 125 shot for 6 months zex kit.stock fuel pump 100 oct,no cats shortie headers(i know not worth the money but is worth the weight reduction and no cats)best pass was 11.52=112 video can be seen at www.putfile.com look under johnoct21 car was breaking up in 4th.i would add a ford gt pump and bap.
Ideally you want to run a tune that is setup for 93 octane. Dyno tune the car with it and get everything dialed in. When you get to the track, just top off the tank with 5 gals of 104 just for added protection from detonation. Not for the sake of adding more timing or anything. With a very safe tune, a 30% mix with 105 which is only 12 points higher, should not effect the a/f ratio enough to cause a lean condition regardless of the stoich point.
You guys that keep recommending a fuel pump upgrade, are you running dry kits? As big a pump that comes in these cars, I can't see it being necessary to change pumps. I have ran wet kits in the past and it only takes a little more fuel to get the proper mixture and a/f ratio. The 255 pump that is stock in these cars should be able to handle that easily.
Matt, I still don't get you reccomending no race-gas.
I found out today that the new gas stationed that opened up a few days ago has 93.
Another question. Is the Zex kit any good? Or would you suggest another kit?
What kits should I avoid?
zex is a great kit...im selling a brand new one with most of the supporting parts for a good price...PM me if interestedI found out today that the new gas stationed that opened up a few days ago has 93.
Thanks for your input. It seemed to me that if Richard, the owner of the succesful and fairly long-standing, mostly Mustang shop Strictly Performance said I didn't need the extra pump for the 125 shot WET ZEX kit, he would know.
