How to open up the grille honeycombs?
Real Horses
Iowa
I am replacing the upper grill and putting the fog lights behind the grille, I noticed on the lower grill that alot of the honeycombs are solid. Has anyone opened these up? Could I start out with a small drill bit and maybe finish up with a dremil? (sp).... Thanks!
irishpwr46
Official Site Vandal
NYC
it would probably be easier to get a coping saw and cut the back off the grill
06Torch
Houston, TX
I think on this site I saw a dude use a hack saw the on the lower grill. He didn't drill a hole from the axis you're thinking (Y) but more like the X axis if the lower grill was sitting on your lap. He said it wasn't as hard as he thought it might be. I've cut on this plastic myself and can tell you that it'll look like total ass at first. When you've done all your cutting find a rough file to smooth everyhing out. I'd also mask everything you don't want the saw to touch. It doesn't take much to marr plastic.
I'll see if I can did that DIY for you.
Good luck,
Gerardo
Real Horses
Iowa
I don't want to cut the grill up just open up the solid honeycombs. I was at a autocross event over the weekend and a guy with a roush 427 mustang had done this to his grill, at that point in time, I didn't ask him how he did it. Thanks guys.
KryptonKnight
Fallston, MD
I did mine using drilled holes at the ends and then using a Coping saw to cut out the honeycombs. Masked the flats to protect. Then using a file to clean up the sawed edge. Truth is, it was a lot of work and almost NO ONE ever even notices it. It is so low that you cannot see it unless you are standing in the next row at a cruise or show. I did it for cooling and looks.
I have seen guys just saw the back of the honeycombs in one operations and that looks the easiest but hardest to control. In the end do it for you and nothing else.
06Torch
Houston, TX
Yeah, I got that. I'm just saying that instead of cutting a honeycomb at a time, you use a coping/hack saw to cut them from the back at once. I think this method would look more even and uniform than doing 14-16 individual honeycombs by drilling/dremeling, etc... You're slicing the back part as opposed to making holes in the solid honeycombs.
Gerardo
06z28eater
Horn Lake, MS
i did mine with a dremel, my cutting wheel broke so i used the grinding piece and holy shit that sucked LOL i think the guy who said about cutting the back side off has the best idea
Real Horses
Iowa
Gerardo
oh gotcha! thank you guys for all your help, actually worded the request wrong, its the top grille that I want to do... 2 hours last nite and its out... holy cripes, alot of interesting ways to get that grille out... lol!
06Torch
Houston, TX
You meant how to remove it from your car???
Gerardo
Shotokan1509
CT
Philostang on this site:
stock05
Atlanta, Ga.
After you cut it like that does it want to stay in place with those tabs being cut off ? I've got the CDC spoiler on the front, does that help hold it in ?
justinS197
Go low or go home!!!
ATL Ga
what he was sayin was about the top grille honey combs being cut out that are full, cause thats what i want to do with mine but there is not a even back side to cut off you have to cut those individually im sure, from what ive seen!
Real Horses
Iowa
Wow thats amazing how to do that, well once I had the grille out I just changed it out to a bar billet grill, if I could figure out how to post pictures easily I would post one, glad I changed out the grille, was able to keep the fog lites, mounted them behind the grille. Thanks guys for all your help and suggestions.
06Torch
Houston, TX
Wow thats amazing how to do that, well once I had the grille out I just changed it out to a bar billet grill, if I could figure out how to post pictures easily I would post one...
Send me the pics. I can host them.
Gerardo
gerardo_lira07 "at" hotmail.com
06Torch
Houston, TX
Found it!
lol! Just learned how to resize pics!!!
Gerardo
Real Horses
Iowa
that was my whole idea behind opening up the grille, so instead I did this :)
Another picture coming to you Gerardo lmao! The second one was a test fit, if you can see I have wires holding up the bottom grille! And, that, guys are how we do it in Iowa...lol Baling twine and fence wire...
