HVAC fan speed
Growingupwithponies
Auburn, IN
06 4.0 Convertible. Automatic. Son’s hvac fan speed was only running on #4. I swapped out the resistor. Fan changes speeds on 1,2&3 but #4 runs same speed as #3. Any suggestions? I tried the relay under the hood with a know working relay. No change.
MrBhp
My guess is a Chinese resistor or faulty control.
Sloane
US
If speeds 1–3 work but 4 matches 3, the blower motor or its wiring for high speed is likely the problem. Check the motor connections, and if they're fine, the motor may need replacing.
VistaBlue09
Washington
It could be a faulty part. Try a Motorcraft brand blower motor resistor to see if the issue persists.
