I can't go into 2nd, 4th and reverse gears. Help
Last night it drove fine this morning it did t go into neither 2nd or 4th entirely it went into reverse for about 3 seconds then bounced back. I have no damn clue what it can be. Any help will be greatly appreciated
fdjizm
Drag Queen
If it's the 3650 you're going to pay more to repair it than buying a good used one.
Got you well first ill get under it and check out if the shifter did not get disalligned or anything before getting a new tranny. Are there are shift stops or bolts?
tcook
what happens if you dbl pump the clutch before shifting into the gear. Does that work?
