I have to change the bolts on my bellhouse?
Midlife Crises
Fairbanks, Alaska
Looking through the 2020 IHRA rule book for little things that might get me dinged this summer and I find the part about not being allowed to use Allen head bolts to attach the bellhouse to the engine. The T56 mag. kit I installed in my 2010 GT came with a SFI approved steel bellhouse and Allen head mounting bolts. Not enough room to use a standard hex head fastener without some sort of spacer. Anybody else had to solve this dilemma?
86GT351
Sunny South Florida
When you are dealing with NHRA tech just get your specific thread pitch on the Allen Bolt and change it to what they require. Not worth getting flagged in Tech.
are you racing in sanctioned events? or just test and tune fun runs?
FWIW - i've been to NHRA tracks to race maybe 20-25 times, never saw a tech guy get under a car or over the top enough to look at the bellhousing
86GT351
Sunny South Florida
True
Midlife Crises
Fairbanks, Alaska
I have not been on a track in many years so test and tune is my focus. If it feels good I’ll run brackets. I have to trailer the car 350 miles one way so failing tech would suck.
MrBhp
Are you running true slicks? If not they are not going to be concerned about the bellhousing or the bolts that hold it on. At least not in my experience. But my local track techs are at times lax. Only if you run sub 11.50's will they begin to really check what they should. Even then it's laughable. When you go sub 10s they wake up. Bunch of hillbillies. All that being said, they are an IHRA sanctioned track.
Midlife Crises
Fairbanks, Alaska
I will be running 28x10.5x15 MT, ET Drags. I think the facility in Palmer operates under IHRA rules. I don’t know how picky they will be. This is a street able vehicle. I could put cats and DOT tires on it and run street legal. I just don’t want to travel 350 miles and not be allowed on the track.
With all the T56 Magnum XL conversions I have seen mentioned I am surprised nobody else has crossed this bridge. It looks to me like a M10,12pt flanged grade 10.9 bolt the correct length will do the job. I’ll give that a shot.
Midlife Crises
Fairbanks, Alaska
Received a set of grade 12.9, M10-1.5X40 bolts in the mail yesterday. 12 point small pattern flanged heads fit perfectly where an Allen head bolt would fit. Now we know.
eighty6gt
no, it's dead material.
idiots....
at worst, use a hardened washer.
eighty6gt
means on a bolt that size the tool pocket is probably inboard of the shear area for the head of the bolt. And if they don't like the contact area for a reduced diameter bolt head you could put a hardened washer under it.
just frustrating is all. Maybe there's something I'm not considering. I'll ask some smarter friends.
