Natural1
all around duguder
Well, that ZF was also introduced about 10 years ago. A lot can happen over the course of 10 years and ZF isn't the only show in town that produces 6-speed autos.
the new 6.2 superduty has a seperate trans controller for the 6r80.
by itself no, it still requires basic pcm input. so far only the 6.2/6r80 superduty has the separate tcm. havent seen the 6.2 raptor setup yet..everything else has a pcm controlled trans...I would guess, that it won't be able to operate as a stand alone type unit. I have noticed that the F150 is available with a 3V 4.6 and 6R80. This may bear fruit, I am not sure. I will research that more.
my wifes 2010 has a 3V 4.6 with the 6R80...and i love it. looking at the specs you provided on the PDF's my assumption would be the 6R80 that will be goin in the 5.0 will be the same one that's in the 5.4...the one that has 5 friction plates and 5 steel plates.I would guess, that it won't be able to operate as a stand alone type unit. I have noticed that the F150 is available with a 3V 4.6 and 6R80. This may bear fruit, I am not sure. I will research that more.
Sport Trac Adrenalin & Raptor Trans!!!
We've got 2![]()
I am trying to understand the functions of the new Ford - CAN (Controller Area Network). If I can figure all of this out, then the transmission itself requires only standard inputs from the vehicle and control of the CAN system.
Any updates??
Here is a link to a 6r80 tranny failure thread with pics of the internals. The failure was due to a missed step in assembly of one of the planetarys.
Failure was not due to design.
Apparently the unit has it own programmable TCU according to the last post in the thread.
THis give hope to transplanting in the 05+ cars imo.
http://www.svtoffroad.com/showthread.php?768-6R80-transmission-failure/page5
