There are always compromises and shortcomings when you have a limited budget. That's just the way of life. That's why I phrased my statement the way I did.
If you're competing on a limited budget, you have to put your money towards those things that will make the greatest difference in performance for the money. So it's going to come down to whether the price difference between Koni (Ground Control) coilovers and MCS coilovers will get you better performance if you spend it on the MCS dampers or on other bits and pieces (e.g., a torque arm).
tires, wheels, dampers/springs, seats. Everything else is incremental.
If the car is strictly for competition, as it is for the OP, then how it rides isn't going to be much of a concern, as long as it's not
too bad.
And as for how it rides, I'm very interested in knowing just how much of a difference there's going to be between a
properly valved Koni-based coilover setup and a monotube damper setup when keeping the spring rates the same, when said spring rates are relatively low (300 lbs/in max in front).
I would say...significant. Granted, I wasn't running a Koni coilover setup, but my ride improved 1300% when I switched to AST's from Koni yellows
You realize, of course, that you're implying that Wiskey11's car rides like ass, right?
It might?
And in an autocross setting, where you're on the track for what, 60 seconds, how much of a difference does that
really make?
You'd be surprised. Dampers get a workout in autox, as it's nearly constant transition, and that what a damper does- convert kinetic energy generated in transition to heat
Context matters.
You think the difference between
properly valved twin tube dampers and monotube dampers would buy you more performance than, say, a torque arm ($1000) plus adjustable sway bars ($500) plus a good panhard bar ($250) for an autocrosser? Seriously??
I agree with Terry. I would easily take coilovers over that stuff. I think the torque arm is a paperweight though...so that's a philosophical thing.
I would expect the difference to make more of a difference for a competition road course driver. For that person, monotube dampers are more likely to be the way to go, but that presumes that there's still sufficient budget remaining for, at least, an adjustable panhard bar.
I think you underestimate the importance of dampers in autox
The GC guys tell me they can put the coilover dampers in a housing that will ensure that, at the preferred ride height, the damper will be at its optimal position. That suggests to me that they can tailor the damper housing length to suit the amount of lowering desired.
That's of great value to me because I plan on lowering my car by only about half an inch since it's a daily driver in an area with crappy streets, steep driveway entrances, and large speed bumps everywhere. And since I'm not in this for competition and won't be using massive (competition level) spring rates, the benefits of monotube dampers probably won't make as much of a difference for me than they would someone else.
Now, if you manage to get Bilstein single-adjustable monotube coilover dampers in housings that would put them at the ideal position when the ride height is only half an inch lower than stock, then you'll have my interest!
That would be a good thing to have. The S197 market needs more simple (single-adjustable) high quality coilovers in the $2000 range
