I need just the bolts that come with the UDPs
DKS
Wax on, Wax off.
VA/NC LINE
I bought a set of used Steeda UDP and when they arrived they only had the 2 pulleys in the box. From what I've read there are supposed to be 2 bolts for the install.
How can I get just the 2 bolts?
Thanks guys
JEWC_Motorsports
S197 Junkie
Texas
you can goto the dealer and get a factory crank bolt. pm me your address and ill send out the install bolt to you.
  • Like
Reactions: DKS
lito
Caracas, Venezuela
the other is a bolt that replaces one of the alternator studs because of the bigger water pulley.
You can get an ARP crank bolt that is reusable.
DKS
Wax on, Wax off.
VA/NC LINE
Ok, I know I need a new crank bolt and the install bolt, but are you saying there is a third bolt for the alternator stud, too?? I didn't realize that.
fdjizm
Drag Queen
NY/NJ
Yes, but I just cut the end off the stud instead. only have to trim it like 2mm anyway.
JEWC_Motorsports
S197 Junkie
Texas
what he said. i actually just took the nut off and used a socket to turn the stud in further. my kit didnt have the alternator bolt either.
JEWC_Motorsports
S197 Junkie
Texas
6A340
Engine Crankshaft Pulley Bolt
4.6L 3v V8 Single Over Head Cam EFI ; M12 x 1.5 x 48MM
$7.32
JEWC_Motorsports
S197 Junkie
Texas
The alternator stud and nut are circled. Th is the one that will either need replaced, ground down, or just tightened in as far as you can get it. I tightened mine in and i havent had an issues with it rubbing or the belt hitting it.
DKS
Wax on, Wax off.
VA/NC LINE
Hell yeah, thanks again for all the info and the bolt.
DKS
Wax on, Wax off.
VA/NC LINE
Looks like it would be easy to just cut the tip off of that stud.
S
Steedagus
Guest
Hi guys, yes you can cut the tip of the stud off if you are missing the bolt we provide to replace the stud.
Also, the install bolt if you need to pick one up locally is a M12 X 1.5 x 60mm, I believe grade 10.9
DKS
Wax on, Wax off.
VA/NC LINE
Thanks bro
