i'm finally home
psycho bob
FISTER
Tulsa, OK
been here for a couple weeks now. got some family time well spent now the new wife is back to work. this is what i've been doing now that i'm on leave.
now have the front cover off and should have the heads off tomorrow. just need to schedule an appointment up in houston for tuning.
usafimj
Welcome home and glad your safe. Good luck with the new family and all
05stroker
Never enough power guy!
Bullard Tx.
Psycho bob welcome back ! What ya doing with the stang ? Motors out so I guess we're fixin to get built !
psycho bob
FISTER
Tulsa, OK
wish i had the funds for the bottom.
heads (JPC stage III), cams (comp spr stage 2), 100 shot, truetrac, frpp 4.10's, bmr k-member, spec aluminum flywheel, spec 3+ clutch, and making my stock charge motion plates into economy plates.
pulling the whole thing because the heads would be a complete pain to remove otherwise. also pulling it only takes an hour out and another one in. also with doing a clutch so might as well.
the nitrous being installed right now depends on if i sell my stock heads/cams immediately. still would need plugs, bottle bracket, and a couple plate gaskets for the kit.
chad05gt
Lake Charles, La
First, WELCOME HOME.
Second, THANK YOU FOR YOUR SERVICE
Looks like you cant tear into that damn thing fast enough!
Good stuff!:thumb:
psycho bob
FISTER
Tulsa, OK
yes i do all my own work. pretty much only thing i haven't done so far is an alignment and now of course i won't be doing the tuning. think i'll leave the short block to the guys at livernois when i eventually do one.
EagleStroker
N/A Junkie
Memphis, TN
If you decide to build it yourself, I might be able to help you out on some internals...
psycho bob
FISTER
Tulsa, OK
thanks, but it's going to be a while before i do the bottom unless something drastic happens. next major job will be the 6 speed trans.
