Install question
Wes06
Pancake.
Hmm. You aren't on TF are you?
Edit. Ahh yea you are. Thought that name looked familure.
leftie712
Finally got my trunk done.
Carpet is glued to center board, used .5" board that seems to work great.
Wes06
floor looks good, is the piece that goes across 1 solid piece?
i wanted mine seperated to be able to easily remove to work on it
still nice lookin
leftie712
still nice lookin
I have 3 parts. Sides with extended support for middle section. Middle section has carpet glued to it so I can just cover sites (just like stock board was).
btw, finishing trunk cut the compressor noise in half, still thinking about adding dynomat to the bottom of the floor since I have few extra sheets.
Wes06
yea thats basically how mine is done, the edges have lips that support the center foldable section i put in.
i just used pegboard and reinforced it with some aluminum channel i had laying around, feels pretty sturdy, may change it some other time but its fine for now :D
and yea putting more carpet and structure around it in the trunk cut down on the noise, but my problem is vibration, it sends it right through the body and you can feel it on the entire car.
gonna have to get some isolators to mount it to and see if thatll help
leftie712
There is no vibrations on mine that I could feel. It could be because I have dynamat installed.
Lansing,MI
You will not believe the difference rubber isolators will make!
leftie712
I have noticed that my rear driver side is close to 1" lower than passenger. Any way to correct this?
