Installing a paxton novi 2200.
Robbinthehood
Not to clutter the thread but what is the spool like on this? Start of boost to full? Looking to do this soon and evaluating this over ford racing as I have brookspeed close which will install and warranty the motor
D98GT
STREETCAR
Liberty TX
You'll see some dyno sheets posted in this thread. The boost rolls on and continues pulling in the upper RPMS but I am sure there is likely a member in your area that will let you ride in his centri car to give you an idea
vic2186
Depends. Hold the brake and press the throttle. If you feel a sift in one direction, there is probably a bad motor or transmission mount on the opposite side.
Is it something I can tighten if I get under the car ?maybe came loose during converter install
chon
Must install Paxton soon!
San Antonio, Texas
About 8 hours into it. The tranny lines were a pain in the ass as well as assembling the pulleys but it's in!
I know I had some questions regarding install but I forgot. Drunk and tired so I'll post an update tomorrow. :)
D98GT
STREETCAR
Liberty TX
Definitely go with the T-bolt clamps and check all of your pipes to ensure they are on snug before slapping the bumper back on
D98GT
STREETCAR
Liberty TX
Haha..yeah not a bad idea to tighten that water pump pulley up. The vent plug will work on the blower if you decide to add an extra bottle into it ;)
Kenaizer
Denver
Haha! Been there.
Oh and make sure you connect your coolant lines and the vacuum line before you get the bay all cluttered with intercooler pipes.
chon
San Antonio, Texas
Thanks guys. I might do a light hit with impact on the water pump pulley. Can't really get them tight because I turn the pulley when torquing down.
I did get the t bolts. which brass plug do I remove to install the breather? There's one on top and one on the side.
Also noticed on the back of JPC reservoir there is a threaded hole. What's it for?
onebadgsx
Houston, TX
The vent goes in the top hole. Side hole is dip stick
