Installing Vortech in the morning
95ragtop
Fayetteville, NC
I will be installing a non i/c V-3 tomorrow. I got a large 5 gallon pan for the coolant, oil for the new injectors, and the tool to remove the fuel lines. Anything I might be missing? Any pearls of wisdom? Thanks as always.
Starfire
Yeah your missing my car to install it on :D I want to get the same kit!
Dr Detail
Keep us posted on how long it takes and some pics of the process would be nice. Good Luck......
Steedman07
Classified's Moderator:)
Connecticut
Make sure you relocate the IAT sensor to after the blower..But Im not sure if Vortech still keeps it inthe same place on the V-3 as they did onthe V2..
Miracle
"Shall not be infringed"
Clarksville, TN
Most importantly, have fun man. I know I'll have a BLAST when I do my Kenne Bell here in a month or so.
Take and post some pics of the progress. :cheers:
95ragtop
Fayetteville, NC
Well I am almost done, I just have to wait for a ride so I can get some tubing for vaccum lines and T conectors, then install spark plugs, KB BAP, and then the tune. Question is I bought the kit used and on the MAF extension can I just use wires to lengthen it? That is what it looks like on the Brenspeed website. Thanks
95ragtop
Fayetteville, NC
Well the install was going good until I tried putting in the last 2 bolts to the blower bracket and the bottom one kept on turning, so I took it off the entire bracket and found that the stud ended up breaking off into the block. Yay!! After so close to being finished. :damnit:. So now I pose the question, How do I get the rest of the bolt out of the block and how can I get a new stud? The car is at a friend's house because he had a garage and I hate to take up his space. Thanks
Start
Problem #1 The PS relocation was pushed against the ECU so I just moved the PS so the two can live happy.
A little something I picked up earlier this week.
I thought I was close to being finished
The final PITA
Beaumont, Tx
Pull the fan and radiator so u can get room. First I would see if there is any part of it sticking out if so use a really good pair of pliars to unscrew it, next take a flat head screw driver and tap it with a hammer till you can get a bite on it sometimes will work. If not try a drill with a left handed drill bit. Worst case drill the damn thing out and helacoil it. Becareful cause if you boo boo up its time for a new timing cover
