The clutch itself will not cause a shifting problem. Improper release adjustment, faulty operation , or a transmission problem are probable causes. To test the clutch system, put the car in first gear with the clutch disengaged and bring the engine up to the rpm where the problem occurs. If the clutch wants to pull or move the car, more release travel is required for the fork or slave cylinder. If there is no tendency to move the car, the problem is in the transmission.
source: http://www.ramclutches.com/Tech/perf_tech.htm
