nbk92
- Joined
- May 19, 2010
- Posts
- 167
- Reaction score
- 0
I just installed a saleen SC. I am having some annoying issues. I get a stumble when stomping on the gas around 2000 RPM. When driving normal, the car stumbles, sputters, and sometimes backfires between 2000 and 2500 RPM. Am I running to rich? I did get a dyno tune, but have to have my tuner look at it again. Another issue I'm having is the car when starting cold, won't start unless I floor the gas pedal. I put the stock plugs back in the car to try and eliminate a spark issue; the car calmed down alot. I got rid of the Brisk plugs and ordered ford racing plugs, will be installed tomorrow. From what I understand, the Brisk plugs, which I had installed, are delicate. I'll keep you posted as to how I make out. Another thing that was suggested to me was I may have a vacuum leak. That said, I am going to take my catch can out and see if that helps. Forgot to mention, The car sometime doesn't hold its idle. Any help or suggestions are appreciated.
Thanks,
Chris
Thanks,
Chris
