retfr8flyr
The Old One
Jason, someone posted you could get the cranks from Lunati, you might give them a call. The big factor with the Eagle cranks is you have to use their rods, due to the journal size.
Earl
Earl
Earl the eagle stroker crank is the only one with the mismatched sizes. Stock stroke had the same size mains as the rest. This is info off of mod max website.
Thanks guys...The car was dropped off at the shop this am to get the block pulled. I'm hoping to deliver the block and the heads to the builder by the end of this next week since I'm going on a cruise.
Fore Stage 2 Return setup was ordered last night. AEM 320 primary with Walbro 465 secondary that will be activated by a Honeywell hobs switch at 2psi. 10an feed, 8 an return.
