Kenne bell blower not producing boost
eighty6gt
So last night I did a test of pulling off the vacuum line opening the BPV valve plugging the vacuum port with my fingure. IT should stay open I am told. Mine slammed shut meaning the float is not opperating fully???
Kenne Bell is sending me a new one either way so my figures are crossed
With no vac, the valve should be closed.
Kenny is so helpful!
lemkau77
Did you get the orifice piece to put into the vacuum line before the BPV and if you did, did you verify that it is installed correctly?
cedarman
New BPV in and she is alive!!!!!! :)
Thanks all for the help. Now on to the next project
TexasBlownV8
Formerly TexasBlownV6
Central Texas
those BPVs seem to cause issues, despite what Kb says. The kit I had apparently had developed a similar issue due a defective valve solenoid.
