DPHC13
- Joined
- Jan 14, 2011
- Posts
- 42
- Reaction score
- 0
Hey guys I'm having a problem with my 2008 GT 5-speed. When I shift I get a "knock". It's like this... Start off in 1st, pushing clutch *knock put into 2nd let off clutch *knock... repeat. It's hard to tell if it's coming from the front or the back. Its easy to replicate all I have to do is drive at a steady pace and let off the gas, when i get back on the throttle it knocks. I am not gunning it back on the gas either i'm just rolling on it. Listen to the video and see if one of you have dealt with this before. I checked the Motor Mounts and they seem good. I've replace the rear lower control arms. It's like when the car is under a load something shifts and knocks. The sound is actually like if you lightly knocked on a door with your fist. Would low oil in the pumpkin maybe cause this? I also checked the driveshaft and nothing is obvious. Their is about a half inch of play when you turn it. Also if i pull on it front to back it moves a little bit. ALSO in the videos I'm giving it gas then letting off then getting back on it thats why its knocking every couple seconds normally it only does it when i shift.
THANKs
http://vid80.photobucket.com/albums...8-D6D1-4F9A-800D-A83E85E40D61_zpskso5txja.mp4
http://vid80.photobucket.com/albums...6-7F1C-4103-A25D-29F01D8677FC_zpszb8yfuk2.mp4
THANKs
